=?GB2312?B?UmU6ILTwuLQ6IFtnZGFsLWRldl0gR0RBTCBDIyBpbnRlcmZhY2U=?=
Tamas Szekeres szekerest at gmail.com
Fri Nov 13 10:57:51 EST 2009
Probaly FWTools or osgeo4w would support hdf4 packages.
Best regards,
Tamas
2009/11/13  <yanbohe at cma.gov.cn>:
> Dear Tamas=A3=AC
> Thanks for your reply and I checked the URLS in your email. Yes there are
> some binary packages supporting C#. But I checked the supporting raster
> formats, I found the one I will to use, HDF4 format is not included. Is
> there any ideas or good suggestions?
> Thanks a lot
> Yanbo
> -----=D3=CA=BC=FE=D4=AD=BC=FE-----
> =B7=A2=BC=FE=C8=CB: Tamas Szekeres [mailto:szekerest at gmail.com]
> =B7=A2=CB=CD=CA=B1=BC=E4: 2009=C4=EA11=D4=C213=C8=D5 23:11
> =CA=D5=BC=FE=C8=CB: yanbohe at cma.gov.cn
> =B3=AD=CB=CD: gdal-dev at lists.osgeo.org
> =D6=F7=CC=E2: Re: [gdal-dev] GDAL C# interface
> Hi,
> You could try one of the packages available from here for example:
> http://vbkto.dyndns.org/sdk/
> Best regards,
> Tamas
>> Dear All,
>> Who have GDAL binary DLL libs for C#? I download the source code and did
> not
>> successes to compile them for C# interface.
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
