[gdal-dev] "Minimalist" GDAL 1.6.2 / 1.6.3 binaries for Windows to work around Xerces binary conflicts?
Tamas Szekeres szekerest at gmail.com
Mon Nov 16 14:25:15 EST 2009
Jason,
It's quite difficult to find out what combination of the dependencies
would be demanding for the users, by taking out the significant
components it would be unusable for most of the users.
I just wanted to mention it's quite straightforward exclude xerces
support and recompile gdal, by using the following steps:
1. Download the SDK package for your compiler/architecture from
http://vbkto.dyndns.org/sdk/ and extract it into a directory
2. Check out the current version of gdal from SVN into the SDK root dir.
3. Open Makefile and remove (or comment out) 'GDAL_XERCES = YES' and
set up 'GDAL_DIR = [gdal directory name]'
4. Open a Visual Studio Command Prompt and type:  'nmake gdal'
Best regards,
Tamas
2009/11/16 Jason Roberts <jason.roberts at duke.edu>:
> Greetings GDAL team,
> The main GDAL download page
> http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries contains a link to
> "minimalist" Windows executables for GDAL 1.6.0, built by Frank W when GDAL
> 1.6.0 was released. Is there any possibility you could offer similar
> binaries of 1.6.2 or the upcoming 1.6.3?
> The only other source of up-to-date GDAL Windows binaries I know of is
> http://vbkto.dyndns.org/sdk/, maintained by Tamas S. These are great, but
> unfortunately I cannot use them because they compile a GDAL driver or
> plug-in that links with xerces-c, and my application loads GDAL in ArcGIS
> and MATLAB processes that also link with xerces-c and there is a DLL
> conflict. This issue came up at GDAL 1.6.0 release time and Frank agreed to
> rerelease the minimalist 1.6.0 binaries without the Xerces dependency. See
> http://trac.osgeo.org/osgeo4w/ticket/31 for more information about that.
> It would be very helpful to me if you could release these minimalist Windows
> executables with every GDAL bugfix release. I have been limping along on
> 1.6.0, waiting for 1.7.0 (when, presumably, minimalist binaries will be
> released again), but I just hit a SWIG issue that causes parts of OGR in
> 1.6.0 to be incompatible with ArcGIS 9.3. This issue was fixed in SWIG
> 1.3.39. Using Tamas's 1.6.2 binaries built with SWIG 1.3.39, I verified that
> the problem is resolved, but I can't use Tamas's binaries in my production
> code due to the Xerces problem.
> So, I am at the point that I will either have to start building minimalist
> binaries 1.6.x myself or delay some new OGR-dependent functionality in my
> app until 1.7.0 minimalist binaries are released (assuming they will be). I
> can figure out how to build myself but I'm hoping that by raising this
> Xerces issue again, you might be convinced that minimalist binaries are
> important enough to release them with every bugfix release. What do you
> think?
> Thanks very much for your consideration,
> Jason
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
