[gdal-dev] tab delimited to shapefile
Jason Roberts jason.roberts at duke.edu
Wed Nov 18 12:55:41 EST 2009
Hi Bruce,
A while ago I wrote a little utility to convert delimited text files to
shapefiles, based on an old version of shapelib. (This is before I knew
about the OGR project.) You can download a copy from ESRI's ArcScripts site
at http://arcscripts.esri.com/details.asp?dbid=14268. It does work on
tab-delimited data, although I don't know whether it will work on the
geonames.org files.
Best,
Jason
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Clay, Bruce
Sent: Wednesday, November 18, 2009 11:10 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] tab delimited to shapefile
Is there any way to use ogr2ogr to convert tab-delimited data such as the
geoname dot org files into shapefiles short of converting all tabs to
commas?
I created a VRT file that works with CSV files but I can not find any way to
convert tab-delimited data.
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you
are
not the intended recipient, you may not use, copy, disclose, or distribute
this
message or its contents or enclosures to any other person and any such
actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091118/f70586dc/attachment.html
