[gdal-dev] tab delimited to shapefile
Kralidis,Tom [Ontario] Tom.Kralidis at ec.gc.ca
Wed Nov 18 14:08:39 EST 2009
I think you can also use the SEPARATOR layer creation option, per
http://www.gdal.org/ogr/drv_csv.html?
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of
> Doug_Newcomb at fws.gov
> Sent: Wednesday, 18 November 2009 13:41
> To: Clay, Bruce
> Cc: gdal-dev at lists.osgeo.org; gdal-dev-bounces at lists.osgeo.org
> Subject: Re: [gdal-dev] tab delimited to shapefile
> Bruce,
> If you're on a linux system with perl:
> perl -pi -e 's/\t/,/g' filename
> is a perl one-liner that should replace all of the tabs with
> commas in the file, working on the file in place. I've used
> similar commands on text files up to 379 GB in size, although
> it does take a while for files that size.
> It does alter the file in place, which can be dangerous. It's
> best to test on a sample of the file :
> head filename> testfile ( take the first 10 lines of the file
> and write it to a separate file) perl -pi -e 's/\t/,/' testfile
> If the testfile works fine, use it on the main file.
> Doug
> Doug Newcomb
> USFWS
> Raleigh, NC
> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> The opinions I express are my own and are not representative
> of the official policy of the U.S.Fish and Wildlife Service
> or Dept. of the Interior. Life is too short for undocumented,
> proprietary data formats.
> Inactive hide details for "Clay, Bruce"
> <bclay at ball.com>"Clay, Bruce" <bclay at ball.com>
> 				Sent by:
> 				11/18/2009 11:09 AM
> To
> <gdal-dev at lists.osgeo.org>
> cc
> Subject
> Is there any way to use ogr2ogr to convert tab-delimited data
> such as the geoname dot org files into shapefiles short of
> converting all tabs to commas?
> I created a VRT file that works with CSV files but I can not
> find any way to convert tab-delimited data.
> Bruce
> This message and any enclosures are intended only for the
> addressee.  Please
> notify the sender by email if you are not the intended
> recipient.  If you are
> not the intended recipient, you may not use, copy, disclose,
> or distribute this
> message or its contents or enclosures to any other person and
> any such actions
> may be unlawful.  Ball reserves the right to monitor and
> review all messages
> and enclosures sent to or from this email
> address._______________________________________________
> gdal-dev mailing list
