[gdal-dev] /usr/lib/libexpat.so: could not read symbols: File in wrong format
Steve Williams williams at csr.utexas.edu
Fri Nov 20 18:08:57 EST 2009
I am trying to compile gdal as per the instructions of the developer of
specialized remote sensing software called gamma
(http://www.gamma-rs.ch/).  The platform is a Dell T410 dual Xeon
processor system with 8GB of memory, running Redhat Enterprise Linux
(RHEL 5.4 x86_64).  The configure goes smoothly, but on the make I am
getting the error on the subject line and the make fails.  The configure
instructions are very specific from gamma:
./configure --without-python --without-php --without-ruby --without-perl
--without-jasper \
--without-curl --without-odbc --with-png=internal
--with-libtiff=internal --with-libgeotiff=internal \
--with-jpeg=internal --with-sqlite=no --with-libz=internal
--without-cfitsio --with-gif=internal --without-netcdf \
--without-pg --without-hdf4 --without-hdf5 --without-geos
--enable-shared --prefix=/usr/local/gdal
the last few lines on the failed make are:
make[1]: Entering directory `/usr/local/src/gdal-1.5.4'
/bin/sh /usr/local/src/gdal-1.5.4/libtool --mode=link   g++
-I/usr/include -lsqlite3 -L/usr/lib -lexpat  -lm -lrt -ldl      -o
libgdal.la /usr/local/src/gdal-1.5.4/frmts/o/*.lo
/usr/local/src/gdal-1.5.4/gcore/*.lo /usr/local/src/gdal-1.5.4/port/*.lo
/usr/local/src/gdal-1.5.4/alg/*.lo
/usr/local/src/gdal-1.5.4/ogr/ogrsf_frmts/o/*.lo
./ogr/ogrgeometryfactory.lo ./ogr/ogrpoint.lo ./ogr/ogrcurve.lo
./ogr/ogrlinestring.lo ./ogr/ogrlinearring.lo ./ogr/ogrpolygon.lo
./ogr/ogrutils.lo ./ogr/ogrgeometry.lo ./ogr/ogrgeometrycollection.lo
./ogr/ogrmultipolygon.lo ./ogr/ogrsurface.lo ./ogr/ogrmultipoint.lo
./ogr/ogrmultilinestring.lo ./ogr/ogr_api.lo ./ogr/ogrfeature.lo
./ogr/ogrfeaturedefn.lo ./ogr/ogrfeaturequery.lo
./ogr/ogrfeaturestyle.lo ./ogr/ogrfielddefn.lo
./ogr/ogrspatialreference.lo ./ogr/ogr_srsnode.lo ./ogr/ogr_srs_proj4.lo
./ogr/ogr_fromepsg.lo ./ogr/ogrct.lo ./ogr/ogr_opt.lo
./ogr/ogr_srs_esri.lo ./ogr/ogr_srs_pci.lo ./ogr/ogr_srs_usgs.lo
./ogr/ogr_srs_dict.lo ./ogr/ogr_srs_panorama.lo ./ogr/ogr_srs_erm.lo
./ogr/swq.lo ./ogr/ogr_srs_validate.lo ./ogr/ogr_srs_xml.lo
./ogr/ograssemblepolygon.lo ./ogr/ogr2gmlgeometry.lo
./ogr/gml2ogrgeometry.lo \
            -rpath /usr/local/gdal/lib \
            -no-undefined \
            -version-info 13:4:12
libtool: link: rm -fr  .libs/libgdal.la.lnkscript
libtool: link: creating GNU ld script: .libs/libgdal.la.lnkscript
libtool: link: g++ -shared -nostdlib
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crti.o
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtbeginS.o
.libs/libgdal.la.lnkscript  -lsqlite3 -L/usr/lib /usr/lib/libexpat.so
-lrt -ldl -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2
-L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64
-L/lib/../lib64 -L/usr/lib/../lib64 -lstdc++ -lm -lc -lgcc_s
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtendS.o
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crtn.o
-Wl,-soname -Wl,libgdal.so.1 -o .libs/libgdal.so.1.12.4
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/usr/local/src/gdal-1.5.4'
make: *** [check-lib] Error 2
anybody seen this before or have a suggested fix?
                    (O O)
 ,-------------- oOO-(_)-OOo -------------,
 |            Stephen Williams            |
 |      Manager of Computer Services      |
 |       Center for Space Research        |
 |     University of Texas at Austin      |
 |     3925 W. Braker Ln., Suite 200      |
 |          Austin, TX 78759-5321         |
 |    512.471.7235  512.471.3570 (fax)    |
 |       williams at csr.utexas.edu          |
 |____________________ Oooo ______________|
                oooO   (   )
                \ (    (_/
                 \_)
