[gdal-dev] /usr/lib/libexpat.so: could not read symbols: File in wrong format
Stephen Williams williams at csr.utexas.edu
Fri Nov 20 21:23:55 EST 2009
that is indeed one way to do it.  and it actually got the make to
finally work.  many thanks.
i'll be checking with red hat on monday to see if there is something
funky about libexpat libraries in 5.4.
also will be checking with the gamma software people to see if there is
something in that library that is needed or not.
many thanks to all that replied.
Frank Warmerdam wrote:
> Steve Williams wrote:
>> I am trying to compile gdal as per the instructions of the developer
>> of specialized remote sensing software called gamma
>> (http://www.gamma-rs.ch/).  The platform is a Dell T410 dual Xeon
>> processor system with 8GB of memory, running Redhat Enterprise Linux
>> (RHEL 5.4 x86_64).  The configure goes smoothly, but on the make I am
>> getting the error on the subject line and the make fails.  The
>> configure instructions are very specific from gamma:
>> -Wl,-soname -Wl,libgdal.so.1 -o .libs/libgdal.so.1.12.4
>> collect2: ld returned 1 exit status
>> make[1]: *** [libgdal.la] Error 1
>> make[1]: Leaving directory `/usr/local/src/gdal-1.5.4'
>> make: *** [check-lib] Error 2
>> anybody seen this before or have a suggested fix?
> Steve,
> I would suggest adding --without-expat to the configure line.  I'm not
> what
> sure is up with your /usr/lib/libexpat.so, but if you don't need it for
> anything just avoid it.
> Best regards,
                    (O O)
 ,-------------- oOO-(_)-OOo -------------,
 |            Stephen Williams            |
 |      Manager of Computer Services      |
 |       Center for Space Research        |
 |     University of Texas at Austin      |
 |     3925 W. Braker Ln., Suite 200      |
 |          Austin, TX 78759-5321         |
 |    512.471.7235  512.471.3570 (fax)    |
 |       williams at csr.utexas.edu          |
 |____________________ Oooo ______________|
                oooO   (   )
                \ (    (_/
                 \_)
