[gdal-dev] Copying text segment header for the NITF driver
Chiou, Kevin kevin.chiou at progeny.net
Tue Nov 24 15:15:11 EST 2009
I noticed that the current GDAL NITF driver does not copy text header
when CreateCopy is performed. So I updated the driver code to perform
the copying.  However, the approach I took adds some additional data to
the dataset's metadata.  I want to check to see if this is ok before I
open a Trac ticket to submit my changes.
NITF Text Domain Before:
DATA_0=This is test text file 01.
DATA_1=This is test text file 02.
NITF Text Domain Now:
HEADER_0=TEXT00000020090407185409SOMETITLE_1...
HEADER_1=TEXT00000020090408185409SOMETITLE_2...
Implementation Notes:
1)	The "HEADER_" metadata contains the whole header in unparsed
form.
2)	The header data has to be stored somewhere in the dataset so I
can read it back when writing it.  I am open to suggestion for putting
the data somewhere else.
 Let me know if this is ok.
-Kevin Chiou
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091124/337dba93/attachment.html
