[Gdal-dev] PROJ.4 EPSG:28992
TomvanTilburg tom.van.tilburg at gmail.com
Thu Nov 26 01:44:27 EST 2009
Never mind, I was too quick in asking.
It appeared to be a corrupted shapefile. Did it again with a new one and
worked like a charm.
TomvanTilburg wrote:
> Hi,
> Im relatively new to the GDAL package but I've got the feeling I'm hitting
> this same (old) problem.
> At the moment I am trying to write a python script that transfers sets of
> shapefiles in the Dutch nation grid (EPSG 28992) to WGS84, ultimately to
> export them to KML files. Therefore I run the following code:
View this message in context: http://n2.nabble.com/PROJ-4-EPSG-28992-tp2033665p4069671.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
