[gdal-dev] Why does OCI driver fail with SRID?
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Mon Nov 30 08:07:12 EST 2009
Hi Mike,
Oh, naturally.  I had forgotten that even I seem to have -lco SRID
parameter included in all the scripts I have written myself.  But how
about appendind the data?  Using -a_srs does not work and using "-lco
SRID=2393" together with "-append" gives a message
"WARNING: Layer creation options ignored since an existing layer is
being appended to."
-Jukka-
Smith, Michael wrote:
> Jukka,
> To set the SRID when loading to Oracle, you have to use the
> layer creation option
> -lco srid=2393
> Mike
> Michael Smith
> RSGIS Center
> US Army Corps of Engineers
> On 11/30/09 7:25 AM, "Jukka Rahkonen"
> <jukka.rahkonen at mmmtike.fi> wrote:
> > Hi,
> > Short question: I cannot get ogr2ogr to co-operate with me
> and Oracle
> > Spatial if I want to set the table SRID by using its EPSG
> code.  I can do what
> > I
> > want by using SQL*Plus but not with ogr2ogr. What am I doing wrong?
> > Longish description follows.
> > I was trying to use ogr2ogr that comes with MS4W 3.0 (dgal
> version 1.7.0dev)
> > for
> > a) Importing a shapefile into Oracle 10g and give SRID at
> the same time.
> > b) Appending date into existing table with SRID set.
> > The SRID I would like to use is epsg:2393.  It is
> configured it in Oracle as
> > can
> > be seen from the following SQL query:
> > select * from mdsys.cs_srs where srid=2393;
> > CS_NAME | SRID |AUTH_SRID |AUTH_NAME |WKTEXT |CS_BOUNDS
> > KKJ / Finland Uniform Coordinate System
> >       2393       2393
> > www.nls.fi/maa/papers/kkj.html
> > PROJCS["KKJ / Finland Uniform Coordinate System",
> > GEOGCS [ "KKJ", DATUM ["Kartasto Koordinaati Jarjestelma 1966
> > (EPSG ID 6123)", SPHEROID ["International 1924 (EPSG ID 7022)",
> > 6378388.0, 297.0], -90.7, -106.1, -119.2, 4.09, 0.218, -1.05,
> > 1.37], PRIMEM [ "Greenwich", 0.000000 ], UNIT ["Decimal Degree",
> > 0.01745329251994328]], PROJECTION ["Finland Uniform Coordinate
> > System (EPSG OP 18193)"], PARAMETER ["Latitude_Of_Origin", 0.0],
> >  PARAMETER ["Central_Meridian", 27.0], PARAMETER
> > ["Scale_Factor", 1.0], PARAMETER ["False_Easting", 3500000.0],
> >  PARAMETER ["False_Northing", 0.0], UNIT ["Meter", 1.0]]
> > Case a) Importing data to new table with ogr2ogr
> > Command:
> > ogr2ogr -f "OCI" OCI:username/passwd at db:test -a_srs
> epsg:2393 test.shp
> > Result: Table is created and features are inserted, but
> without SRID set.
> > Ogr2ogr is trying to insert a new line into the table
> MDSYS.CS_SRS but it
> > fails
> > because of insufficient privileges
> > ERROR 1: ORA-01031: insufficient privileges
> >  in INSERT INTO MDSYS.CS_SRS (SRID, WKTEXT, CS_NAME)
> >  VALUES (1000003006,'PROJCS["KKJ / Finland Uniform Coordinate
> > System",GEOGCS["KKJ",DATUM["Kartastokoordinaattijarjestelma_1966",
> > SPHEROID["International 1924",6378388,297]],PRIMEM["Greenwich",0],
> > UNIT["Decimal Degree",0.0174532925199433]],UNIT["metre",1],
> > PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],
> > PARAMETER["central_meridian",27],PARAMETER["scale_factor",1],
> > PARAMETER["false_easting",3500000],PARAMETER["false_northing",0]]',
> >  'KKJ / Finland Uniform Coordinate System' )
> > I wonder why org2ogr is trying to add the projection,
> because SRID 2393 is
> > already defined in the database, and why it would like to
> insert my SRID=2393
> > with code "1000003006".
> > Case b) Appending data into table having SRID=2393
> > Command:
> > ogr2ogr -update -append -f "OCI" OCI:username/passwd at db:test
> >  -a_srs epsg:2393 test2.shp
> > This fails with Oracle error ""Layer SRID does not match
> geometry SRID". I can
> > make the insert to succeed by dropping the spatial index of
> the table, but
> > then
> > the newly inserted features have SRID=null.
> > -Jukka Rahkonen
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
