[gdal-dev] Re: GDAL 1.7.0 download?
Chris Emberson chrisemberson at hotmail.com
Thu Oct 1 07:41:32 EDT 2009
Thanks for the reply.
Do you have any idea when 1.7.0 will be released?
Or can you advise the procedure for backporting?
> Date: Tue, 29 Sep 2009 20:09:23 +0200
> From: peifer at gmx.eu
> To: even.rouault at mines-paris.org
> CC: chrisemberson at hotmail.com; gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Re: GDAL 1.7.0 download?
> You are right. Now I remember that some time ago, I made an extra effort
> to get hold of this useful utility...
> Hermann
> Even Rouault wrote:
> > Selon Hermann Peifer <peifer at gmx.eu>:
> > Well, the documentation is correct. gdaldem will be officially included in
> > to-be-released GDAL 1.7.0.
> > http://trac.osgeo.org/gdal/browser/branches/1.6/gdal/apps doesn't show any sign
> > of it...
> > I guess you have backported it yourself or someone did it for you. The source
> > code should indeed compile fine against any GDAL version.
> >> Chris Emberson wrote:
> >>> Hi,
> >>> Am trying to use gdaldem but it says this is only available with GDAL
> >> 1.7.0,
> >>> "Tools to analyze and visualize DEMs. (since GDAL 1.7.0)"
> >> As far as I can see, the documentation is not correct in this case.
> >> $ gdaldem  --version|head -1
> >> GDAL 1.6.2, released 2009/07/31
> >> Hermann
> >> _______________________________________________
> >> gdal-dev mailing list
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
_________________________________________________________________
With Windows Live, you can organise, edit, and share your photos.
http://clk.atdmt.com/UKM/go/134665338/direct/01/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091001/d8b09c15/attachment.html
