[gdal-dev] compiling GDAL with GEOS on Windows
Yilmaz Arslanoglu
yilmaz.arslanoglu at gmail.com
Fri Oct 2 04:05:30 EDT 2009
Hi Bhasker;
I use Visual Studio 2008, but actually the problem was
forgetting to make a complete clean before building it with
the modified options. So as Frank said, it will be nice
to call "nmake /f makefile.vc clean" before the build.
Regards,
Yilmaz
On Fri, Oct 2, 2009 at 9:14 AM, spbhasker bachi <spbhasker at gmail.com> wrote:
> hi.
> which version of vc++ are you using..
> coz if u are using vc++ 6.0 you need to make some changes in some codes.
> also do study the nmake.opt file & check i all the paths are set properly.
> hope this helps..
> bhasker
> On Thu, Oct 1, 2009 at 10:24 PM, Yilmaz Arslanoglu
> <yilmaz.arslanoglu at gmail.com> wrote:
>> Hi;
>> I am trying to build and install the GDAL library on Windows XP
>> using the following commands:
>> nmake /f makefile.vc install
>> nmake /f makefile.vc devinstall
>> In order to build with GEOS support, I uncommented the lines
>> in the "nmake.opt" as follows:
>> GEOS_DIR=C:\geos-3.1.1
>> GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/source/headers -DHAVE_GEOS
>> GEOS_LIB = $(GEOS_DIR)/source/geos_c_i.lib
>> However, I still get the same .dll and .lib files as if no GEOS
>> support was turned on
>> (the sizes are exactly the same). When I try to call
>> "OGRGeometry::Contains()" method,
>> I also get the error:
>> "ERROR 6: GEOS support not enabled."
>> What could be wrong?
>> 2) I was also wondering whether OGR library provides a kind of nearest
>> neighbour finding facilities?
>> If not, does anybody know any library that could be integrated with
>> OGR for this purpose?
>> I plan to use it to find the n nearest sounding points (SOUNDG)
>> given a point, to make a prediction
>> about its depth.
>> 3) Finally, is there any facility in OGR for querying a layer such that
>> it will only return the features on it, which contain a given
>> point as parameter?
>> Because I could not come up with an SQL statement to perform this task.
>> Actually I was planning to use this on the DEPARE (depth area) layer on
>> an S-57 file to find the depth area polygon that covers the given
>> point.
>> Any idea or references about these issues would greatly be
>> appreciated.
>> Best regards,
>> Yilmaz
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
