[gdal-dev] ogrinfo ends its work as soon as it starts
Randy randyqiuxy at hotmail.com
Wed Oct 7 01:24:37 EDT 2009
Hi list,
I want to get all fields and their corresponding values of a feature by
using function:"OGRFeature::GetFieldAsString()". Then, I got
RCID 7
PRIM 1
GRUP 2
OBJL 9
RVER 1
AGEN 550
FIND 143752687
FIDS 2738
LNAM 022608917DEF0AB2
LNAM_REFS (1:022608917DD60AB2)
But I fail to retrieve feature's attribute field. For instance, when I got a
"WRECKS" which was indicated by "OBJL = 159", I should be able to get its
attribute field like
CATWRK = .
QUASOU = .
WATLEV = .
Under Mr Chaitanya's guidance, I set environment variable OGR_S57_OPTIONS =
"RETURN_LINKAGES=ON,RETURN_PRIMITIVE=ON,RETURN_REFS=ON", but it doesn't work
very well and I still got nothing relevant attribute field info.
Therefore, I doubt there is something wrong with my ENC file and want to use
"ogrinfo.exe" for testing. However, the window disappear as soon as it
appear when I dblclick it and so does some other application like
gdalwarp.exe.
Anyone could give me suggestion?
Best Regards,
Randy
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091007/fafe2f25/attachment.html
