[gdal-dev] Doing segment-wise statistics
Jose Gomez-Dans jgomezdans at gmail.com
Fri Oct 9 06:45:42 EDT 2009
Hiya,
2009/10/9 Peder Axensten <peder at axensten.se>
> I'd like to do some segment-wise statistics (mean, standard deviation,
> etc.) on rasters.
> The segments will be defined by polygons in a shapefile.
> I need to do this in a Python script, so anything without a GUI is fine.
> Is there a solution I can use?
This is similar to what you want to do:
<http://sites.google.com/site/spatialpython/zonal-statistics>
Cheers,
Jose
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091009/ac33ce29/attachment.html
