[gdal-dev] Python-OGR not looping over more than 500 PGSQL features
Matthieu Rigal rigal at rapideye.de
Fri Oct 9 06:41:28 EDT 2009
Hi people,
I recently discovered a strange behaviour which was not happening before, I
I'm using Python 2.5 with GDAL/OGR 1.6 and PGsql 8.3 on Linux.
I am reading a table containing 858 features with several columns and
I first do a SELECT on the table and the GetFeatureCount tells me 858 lines
are being readen.
Then I am looping on the OGR object Feature by feature, to make some
calculation and I send an UPDATE for this particular line through another OGR
I have a counter after every UPDATE.
Whereas it should go through all the 858 features, it stops after having gone
through 500 features, my counter at the end shows 500 and looking to the
database, it clearly stops after 500.
I've done a test on a second database and it also stopped at 500...
Is there some recently introduced limitations on OGR side ? I have searched
all the website without finding something about it... May it come from some
Python memory limitation ( I doubt) ? Or from some PGSQL server limitation (I
doubt also because 858 features are returned at the beginning ?
Thanks for your help,
Best Regards,
Matthieu Rigal
RapidEye AG
Molkenmarkt 30
14776 Brandenburg an der Havel
Follow us on Twitter! www.twitter.com/rapideye_ag
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Wolfgang G. Biedermann
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates:
Juergen Breitkopf
Commercial Register/Handelsregister Potsdam HRB 17 796
Tax Number/Steuernummer: 048/100/00053
VAT-Ident-Number/Ust.-ID: DE 199331235
DIN EN ISO 9001 certified
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
The information in this e-mail is intended for the named recipients
only. It may contain privileged and confidential information. If you
have received this communication in error, any use, copying or
dissemination of its contents is strictly prohibited. Please erase all
copies of the message along with any included attachments and notify
RapidEye AG or the sender immediately by telephone at the number
indicated on this page.
