答复: Re: [gdal-dev] different result of ogrinfo between GDAL/OGR and FWTools
Randy randyqiuxy at hotmail.com
Sun Oct 11 04:55:45 EDT 2009
Chaitanya,
Thanks you, Chaitanya!
To be frank, I don’t  understand what  you mean. Could you give me some more explicit guidance and where I should change the version option? I use the latest stable GDAL/OGR release version-1.6.2 and FWTools-2.4.5, but ogrinfos from them result in different results. And what I get from my own application based on OGR equal with what ogrinfo of GDAL/OGR get. However, it lost something comparing with FWTools’s ogrinfo.
Besides that, I find the environment variable “OGR_S57_OPTIONS“ doesn’t work and the result didn’t change after I set the variable and restart my PC.
Anyone knows why?
Thanks again!!
Best regards,
Randy
发件人: Chaitanya kumar CH [mailto:chaitanya.ch at gmail.com]
发送时间: 2009年10月11日 15:15
收件人: Randy
抄送: GDAL/OGR mailing list
主题: [?? Probable Spam] Re: [gdal-dev] different result of ogrinfo between GDAL/OGR and FWTools
Randy,
Perchance, the versions were different. Try the --version option.
On Sun, Oct 11, 2009 at 11:55 AM, Randy <randyqiuxy at hotmail.com> wrote:
Hi list,
I find the ogrinfo which GDAL/OGR source code produced cannot get all fields(such as attribute fields) of a feature(s_57), while the ogrinfo in fwtools can make it.
Anyone knows its reason?
Thanks in advance!
Best regards,
Randy
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091011/df2fca70/attachment.html
