[gdal-dev] different result of ogrinfo between GDAL/OGR and FWTools
Mateusz Loskot mateusz at loskot.net
Sun Oct 11 08:43:22 EDT 2009
Randy wrote:
> Hi list,
> I find the ogrinfo which GDAL/OGR source code
Which version? There are number of versions of GDAL thus number of
versions of ogrinfo.
> produced cannot get all fields(such as attribute fields) of a
> feature(s_57), while the ogrinfo in fwtools can make it.
If you have problem with any particular command and its results,
it is almost mandatory to provide example of commands and their results
so everybody can see how the problem leaks.
Otherwise, it's not really possible to help.
> Anyone knows its reason?
No reason, unless you provide more precise information
http://catb.org/~esr/faqs/smart-questions.html#beprecise
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
