[gdal-dev] building perl swig with MingW
guillaume huby guillaume.huby.lists at gmail.com
Mon Oct 12 11:42:18 EDT 2009
Hello,
I experience some troubles building perl bindings on MingW.
Here is my config :
Windows XP;
MingW 5.1.6 + MSys;
Gdal1.6.2 sources from website;
ActivePerl 5.10;
I successfully built gdal library using MingW. Then I build perl bindings :
perl Makefile.pl -> everything looks fine;
dmake -> no error message;
dmake test -> error message :
<PerlPath>\bin\perl.exe "-MExtUtils::Command::MM" "-e" "test_harness(0,
'blib\lib', 'blib\arch')" t/*.t
t/gdal....
#   Failed test 'use Geo::GDAL;'
#   at t/gdal.t line 2.
#     Tried to use 'Geo::GDAL'.
#     Error:  Can't load
'<Gdal_source_path>\swig\perl\blib\arch/auto/Geo/OGR/OGR.dll' for module
Geo::OGR: load_file: Access to this memory location is not valid at
<PerlPath>/lib/DynaLoader.pm line 202.
#  at <Gdal_source_path>\swig\perl\blib\lib/Geo/OGR.pm line 12
# Compilation failed in require at
<Gdal_source_path>\swig\perl\blib\lib/Geo/GDAL.pm line 571.
# BEGIN failed--compilation aborted at t/gdal.t line 2.
# Compilation failed in require at (eval 3) line 2.
# BEGIN failed--compilation aborted at (eval 3) line 2.
Name "swig_runtime_data::type_pointer3" used only once: possible typo at
<PerlPath>/lib/DynaLoader.pm line 225.
Undefined subroutine &Geo::GDAL::GetDriver called at t/gdal.t line 57.
# Looks like you failed 1 test of 1.
The "<Gdal_source_path>\swig\perl\blib\arch/auto/Geo/OGR/OGR.dll" file
successfully pass dependency walker test.
Does anyone has an idea of what went wrong ? Did I missed something
somewhere ?
Thanks for replies !
Regards,
Guillaume.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091012/62f31ba9/attachment.html
