[gdal-dev] gdal.h: No such file or directory
Peter J Halls P.Halls at york.ac.uk
Tue Oct 13 02:12:33 EDT 2009
Should it not be #include "gdal.h"?  The <> construct is used for system
includes, whereas gdal.h counts as a user include, to be found in the include
path.  But I admit my c to be a little rusty ...  Peter
Riki Tiki wrote:
> Hi,
> I am using bloodshed dev-C++...
> I have written only this
> #include <stdio.h>
> #include <stdlib.h>
> #include <gdal.h>
> int main(int argc, char *argv[])
>   system("PAUSE");
>   return 0;
> Before compiling it i have installed the FWTools2.4.5,
> all header files are located in
> C:\Program Files\FWTools2.4.5\include
> Now before compiling and running above program
> i have added to the
> Tools->Compiler Options->Directories->Libraries
> the above path of the fwtools' include folder...
> when i compile and run it... it says the following:
> C:\...\main.c gdal.h: No such file or directory.
> C:\...\Makefile.win [Build Error]  [main.o] Error 1
> can you help me to solve the problem?
> thanks a lot in advance.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Peter J Halls, GIS Advisor, University of York
Telephone: 01904 433806     Fax: 01904 433740
Snail mail: Computing Service, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
