[gdal-dev] grass lib not found : gdal-grass plug-in (grass-7.0)
Markus Neteler neteler at osgeo.org
Wed Oct 14 13:09:26 EDT 2009
On Wed, Oct 14, 2009 at 12:02 PM, Massimo Di Stefano
<massimodisasha at yahoo.it> wrote:
> Hi All.
> I'm tring to build the gdal-grass plug-in (i'm using gdal from svn)
> on a debian sid machine,
> i had this problem :
> geofem at geofem:/usr/local/src/gdal/frmts/grass/gdal-grass-1.7.0$ ./configure
> --with-gdal=/usr/local/bin/gdal-config
> --with-grass=/usr/local/grass-7.0.svn/
> configure: error: --with-grass=/usr/local/grass-7.0.svn requested, but
> libraries not found!  Perhaps you need to set LD_LIBRARY_PATH to include
> /usr/local/grass-7.0.svn/lib?
> i have  :
> cat /etc/ld.so.conf.d/grass.conf
> have you any clue on how to fix the gdal-grass build ?
Yes, see the patch in
http://trac.osgeo.org/gdal/ticket/2953
Markus
