[gdal-dev] opening an S-57 dataset directory
gdal user mrxonx at hotmail.com
Sat Oct 17 23:26:53 EDT 2009
I think there is a bit more there than that. The driver (at least the
older version we use) will also deal with the multi-level style Primar
format systems.
Frank Warmerdam wrote:
> The driver will only find update files if they are in the same directory
> as the .000 file, have names like .001, etc and a shared basename.
> Best regards,
