[gdal-dev] opening an S-57 dataset directory
gdal user mrxonx at hotmail.com
Sun Oct 18 22:37:45 EDT 2009
Frank,
I am just reading the code in s57reader.cpp.
It does look like there is code there to search directories in Primar
format. Look right after the line that reads: "else // file is store on
Primar generated cd".
--Mike
Frank Warmerdam wrote:
> Mr. Xonx,
> Can you give more information on this?  Do you mean specifically with
> regard
> to finding update files, or with regard to supporting directories of S-57
> files?
> What version are you using?  How are the Primar datasets organized?
> Best regards,
