Re: [gdal-dev] Date tag in geotiff files
Ivan ivan.lucena at pmldnet.com
Mon Oct 19 12:47:22 EDT 2009
Martin,
An easy-dirt way is just add Metadata Items to it. That is how I am doing:
    output_dst.SetMetadataItem('STARTDATE',     start_date.isoformat(), '')
    output_dst.SetMetadataItem('STARTTIME',     start_time.isoformat(), '')
That would work as long as you are the same guy who writes the piece of code that read that data (stored on
GDAL auxiliary XML files, not on TIFF tags by the way).
Would be nice if we could use a standard Metadata schema.
Regards,
Ivan
>  -------Original Message-------
>  From: Raspaud Martin <martin.raspaud at smhi.se>
>  Subject: [gdal-dev] Date tag in geotiff files
>  Sent: Oct 19 '09 10:33
>  Hi,
>  I'm currently working with satellite images, and for this I use GDAL's
>  python interface.
>  I would like to add a date in the metadata of the geotiff files I use. I
>  looked around the gdal website, but I couldn't find anything about this.
>  Is there a way to do this from gdal ? Should I use exif metadata ? Any
>  other way ?
>  Thanks,
>  Martin
>  _______________________________________________
>  gdal-dev mailing list
>  [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
>  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
