[Gdal-dev] gdal-1.6.2 compile fail (mpi.h)
alfreale alfreale74 at gmail.com
Wed Oct 21 09:52:53 EDT 2009
I try to compile gdal with hdf5 support, but the compile fail:
In file included from /usr/include/hdf5.h:24,
                 from hdf5dataset.cpp:34:
/usr/include/H5public.h:57:20: error: mpi.h: No such file or directory
In file included from /usr/include/hdf5.h:46,
/usr/include/H5FDmpi.h:66: error: expected identifier before '*' token
/usr/include/H5FDmpi.h:66: error: 'MPI_Comm' declared as function returning
a function
In file included from /usr/include/H5FDmpi.h:71,
/usr/include/H5FDmpio.h:50: error: 'MPI_Comm' has not been declared
/usr/include/H5FDmpio.h:50: error: 'MPI_Info' has not been declared
/usr/include/H5FDmpio.h:51: error: 'MPI_Comm' has not been declared
/usr/include/H5FDmpio.h:52: error: 'MPI_Info' has not been declared
In file included from /usr/include/H5FDmpi.h:72,
/usr/include/H5FDmpiposix.h:46: error: 'MPI_Comm' has not been declared
/usr/include/H5FDmpiposix.h:47: error: 'MPI_Comm' has not been declared
/usr/include/H5FDmpi.h:99: error: 'MPI_Offset' was not declared in this
scope
/usr/include/H5FDmpi.h:100: error: 'MPI_Offset' has not been declared
/usr/include/H5FDmpi.h:101: error: 'MPI_Comm' was not declared in this scope
/usr/include/H5FDmpi.h:101: error: 'MPI_Info' was not declared in this scope
/usr/include/H5FDmpi.h:102: error: 'MPI_Comm' was not declared in this scope
/usr/include/H5FDmpi.h:102: error: 'comm_new' was not declared in this scope
/usr/include/H5FDmpi.h:102: error: 'MPI_Info' was not declared in this scope
/usr/include/H5FDmpi.h:102: error: 'info_new' was not declared in this scope
/usr/include/H5FDmpi.h:102: error: initializer expression list treated as
compound expression
/usr/include/H5FDmpi.h:103: error: 'MPI_Comm' was not declared in this scope
/usr/include/H5FDmpi.h:103: error: 'comm' was not declared in this scope
/usr/include/H5FDmpi.h:103: error: 'MPI_Info' was not declared in this scope
/usr/include/H5FDmpi.h:103: error: 'info' was not declared in this scope
/usr/include/H5FDmpi.h:103: error: initializer expression list treated as
compound expression
/usr/include/H5FDmpi.h:108: error: 'MPI_Datatype' has not been declared
/usr/include/H5FDmpi.h:109: error: 'MPI_Datatype' has not been declared
/usr/include/H5FDmpi.h:115: error: 'MPI_Comm' does not name a type
make[2]: *** [../o/hdf5dataset.lo] Error 1
make[2]: Leaving directory
`/home/alfredo/archivio/GRASS_INSTALL/gdal-1.6.2/frmts/hdf5'
make[1]: *** [hdf5-install-obj] Error 2
make[1]: Leaving directory
`/home/alfredo/archivio/GRASS_INSTALL/gdal-1.6.2/frmts'
make: *** [frmts-target] Error 2
View this message in context: http://n2.nabble.com/gdal-1-6-2-compile-fail-mpi-h-tp3865413p3865413.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
