[Gdal-dev] gdal-1.6.2 compile fail (mpi.h)
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Oct 21 10:43:22 EDT 2009
alfreale,
Looks like this problem is related to hdf5 and mpi. IMHO you should check
your mpi and hdf5 packages.
On Wed, Oct 21, 2009 at 7:22 PM, alfreale <alfreale74 at gmail.com> wrote:
> Hi,
> I try to compile gdal with hdf5 support, but the compile fail:
> In file included from /usr/include/hdf5.h:24,
>                 from hdf5dataset.cpp:34:
> /usr/include/H5public.h:57:20: error: mpi.h: No such file or directory
> In file included from /usr/include/hdf5.h:46,
> /usr/include/H5FDmpi.h:66: error: expected identifier before '*' token
> /usr/include/H5FDmpi.h:66: error: 'MPI_Comm' declared as function returning
> a function
> In file included from /usr/include/H5FDmpi.h:71,
> /usr/include/H5FDmpio.h:50: error: 'MPI_Comm' has not been declared
> /usr/include/H5FDmpio.h:50: error: 'MPI_Info' has not been declared
> /usr/include/H5FDmpio.h:51: error: 'MPI_Comm' has not been declared
> /usr/include/H5FDmpio.h:52: error: 'MPI_Info' has not been declared
> In file included from /usr/include/H5FDmpi.h:72,
> /usr/include/H5FDmpiposix.h:46: error: 'MPI_Comm' has not been declared
> /usr/include/H5FDmpiposix.h:47: error: 'MPI_Comm' has not been declared
> /usr/include/H5FDmpi.h:99: error: 'MPI_Offset' was not declared in this
> scope
> /usr/include/H5FDmpi.h:100: error: 'MPI_Offset' has not been declared
> /usr/include/H5FDmpi.h:101: error: 'MPI_Comm' was not declared in this
> scope
> /usr/include/H5FDmpi.h:101: error: 'MPI_Info' was not declared in this
> scope
> /usr/include/H5FDmpi.h:102: error: 'MPI_Comm' was not declared in this
> scope
> /usr/include/H5FDmpi.h:102: error: 'comm_new' was not declared in this
> scope
> /usr/include/H5FDmpi.h:102: error: 'MPI_Info' was not declared in this
> scope
> /usr/include/H5FDmpi.h:102: error: 'info_new' was not declared in this
> scope
> /usr/include/H5FDmpi.h:102: error: initializer expression list treated as
> compound expression
> /usr/include/H5FDmpi.h:103: error: 'MPI_Comm' was not declared in this
> scope
> /usr/include/H5FDmpi.h:103: error: 'comm' was not declared in this scope
> /usr/include/H5FDmpi.h:103: error: 'MPI_Info' was not declared in this
> scope
> /usr/include/H5FDmpi.h:103: error: 'info' was not declared in this scope
> /usr/include/H5FDmpi.h:103: error: initializer expression list treated as
> compound expression
> /usr/include/H5FDmpi.h:108: error: 'MPI_Datatype' has not been declared
> /usr/include/H5FDmpi.h:109: error: 'MPI_Datatype' has not been declared
> /usr/include/H5FDmpi.h:115: error: 'MPI_Comm' does not name a type
> make[2]: *** [../o/hdf5dataset.lo] Error 1
> make[2]: Leaving directory
> `/home/alfredo/archivio/GRASS_INSTALL/gdal-1.6.2/frmts/hdf5'
> make[1]: *** [hdf5-install-obj] Error 2
> make[1]: Leaving directory
> `/home/alfredo/archivio/GRASS_INSTALL/gdal-1.6.2/frmts'
> make: *** [frmts-target] Error 2
> http://n2.nabble.com/gdal-1-6-2-compile-fail-mpi-h-tp3865413p3865413.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091021/5d5362cb/attachment.html
