[gdal-dev] open source tool
Roger André randre at gmail.com
Wed Oct 21 14:47:01 EDT 2009
This could be done with GRASS, I think.  First extract the LAS file
into an ASCII x,y,z file.  Then load into GRASS with r.in.xyz. Then
use one of the v.delaunay or v.voronoi GRASS modules.
Roger
2009/8/27 Riki Tiki <mongoose_riki at mail.ru>:
> hi,
> do you know any tools available for the conversion of LAS (LIDAR data) into Voronoi diagrams or TIN (triangular irregular networks)? thanks a lot!
> or anyone can suggest how to do it in arcgis for example?
> thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
