[Gdal-dev] GDALOpenShared error
alfreale alfreale74 at gmail.com
Fri Oct 23 07:17:40 EDT 2009
When I import a HDF file with gdal, I've this error:
A dataset opened by GDALOpenShared should have the same filename.....
GRASS 6.4.0RC5 (wgs84_lat_long):~ > i.in.spotvgt -a --overwrite --verbose
file=/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF
rast=ndvi_test
Importing SPOT VGT NDVI map...
Warning 6: A dataset opened by GDALOpenShared should have the same filename
(/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF)
and description
(HDF4_SDS:UNKNOWN:"/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF":0)
View this message in context: http://n2.nabble.com/GDALOpenShared-error-tp3878105p3878105.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
