[gdal-dev] What can OGR do with SpatiaLite files at this moment and in the near future?
Tamas Szekeres szekerest at gmail.com
Sun Oct 25 07:40:24 EDT 2009
Dan,
FYI: I've added SpatialLite support to the binary packages available to
download from here:
http://vbkto.dyndns.org/sdk/
You could also find the SpatialLite libs and header files in the
corresponding SDK packages.
Best regards,
Tamas
2009/10/24 Dan Putler <dan.putler at sauder.ubc.ca>
> Hi all,
> On the R-Sig-Geo list there is a thread going on related to using
> SpatiaLite as a file based store of vector geodata. The first issue that
> comes up is what can OGR do with SpatiaLite files both now, and in the
> near future? My understanding (which may well be wrong) is that there is
> a SQLite read-only driver in GDAL/OGR 1.6.X versions. My first specific
> question, assuming my understanding is correct, is whether OGR can read
> the geometry field in a SpatiaLite file? My second question is whether
> there are any current plans to extend the SQLite driver to enable it to
> write SpatiaLite files? My final question is more on the FWTools front,
> and that is whether the current Windows version of FWTools has a build
> of the GDAL/OGR library that has both the SQLite and PostGIS drivers
> included?
> Dan
> Dan Putler
> Sauder School of Business
> University of British Columbia
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091025/ebd538df/attachment.html
