[gdal-dev] gdal java binding jpip
Kunzman, Douglas DKUNZMAN at overwatch.textron.com
Mon Oct 26 16:02:23 EDT 2009
Even -
It tried the 1.3.39 branch with no problems. So I assume the problem
might be in Norman's sandbox?  I'm going try it under cygwin before
bugging him again.
Doug
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Monday, October 26, 2009 2:16 PM
To: Kunzman, Douglas
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] gdal java binding jpip
Selon "Kunzman, Douglas" <DKUNZMAN at overwatch.textron.com>:
I haven't tried compiling Norman's sandbox, but could you retry with
just SVN
trunk and see if you still get the error ? The SWIG version you use is
also an
important factor as it breaks quite easily when you switch from one
version to
another one. Trunk Java bindings are known to build fine with swig
1.3.39.
> I am trying to compile the java samples under
> http://svn.osgeo.org/gdal/sandbox/normanb/
> <http://svn.osgeo.org/gdal/sandbox/normanb/>  for use with jpip.  I
> believe this is a general gdal compile issue but I'm not sure.  I'm
new
> to gdal and have searched the web and have found no good information.
> When I type
> swig> -f makefile.vc java
> Using Visual Studio 2005 and Win32/XP
> I get the following error message,
>         C:\Program Files\Microsoft Visual Studio
> 8\VC\INCLUDE\string.h(215) : see declaration of 'stricmp'
> gdal_wrap.cpp(1129) : warning C4996: 'stricmp': The POSIX name for
this
> item is
> deprecated. Instead, use the ISO C++ conformant name: _stricmp. See
> online help
> for details.
> gdal_wrap.cpp(4412) : error C2451: conditional expression of type
'void'
> is illegal
>         Expressions of type void cannot be converted to other types
> gdal_wrap.cpp(4412) : error C2541: 'delete' : cannot delete objects
that
> are not
>  pointers
> gdal_wrap.cpp(4414) : error C2120: 'void' illegal with all types
> I have been looked at the error message and they are implying that
> gdal_wrapp.cpp is not standard C++?  Is this possible?
> Any help would be appreciated,
> Thanks Doug
