[gdal-dev] How to submit a fix?
Chiou, Kevin kevin.chiou at progeny.net
Mon Oct 26 18:15:06 EDT 2009
Hi:
  I am fairly new to the GDAL community can someone point me to the
right direction for submitting a GDAL fix.
  Basically I found a minor problem in the GDAL Python binding. This is
related to http://trac.osgeo.org/gdal/ticket/3088: "do not remove
leading spaces after TRE=xxxx"  The Python wrapper trims white spaces
when GetMetadata() is called, which is not desired for NITF TRE data. I
found the problem in the wrapper code and updated it.
  Do I just have to open a GDAL Trac ticket and attach the fix?
Thank you,
Kevin Chiou
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091026/da186940/attachment-0001.html
