[gdal-dev] How to submit a fix?
Even Rouault even.rouault at mines-paris.org
Mon Oct 26 18:39:25 EDT 2009
Selon "Chiou, Kevin" <kevin.chiou at progeny.net>:
> Hi:
>   I am fairly new to the GDAL community can someone point me to the
> right direction for submitting a GDAL fix.
>   Basically I found a minor problem in the GDAL Python binding. This is
> related to http://trac.osgeo.org/gdal/ticket/3088: "do not remove
> leading spaces after TRE=xxxx"  The Python wrapper trims white spaces
> when GetMetadata() is called, which is not desired for NITF TRE data. I
> found the problem in the wrapper code and updated it.
>   Do I just have to open a GDAL Trac ticket and attach the fix?
Yes, that's the usual procedure to collect patches
> Thank you,
> Kevin Chiou
