[gdal-dev] building perl swig with MingW
guillaume huby guillaume.huby.lists at gmail.com
Wed Oct 28 11:40:09 EDT 2009
Dear Ari,
On Wed, Oct 28, 2009 at 3:53 PM, Ari Jolma <ari.jolma at gmail.com> wrote:
> guillaume huby kirjoitti:
>  Hello,
>> I experience some troubles building perl bindings on MingW.
>> Here is my config :
>> Windows XP;
>> MingW 5.1.6 + MSys;
>> Gdal1.6.2 sources from website;
>> ActivePerl 5.10;
> The problem is that ActivePerl is compiled with VC and you can't mix
> MinGW,which uses gcc, with that.
> Compiling Perl with MinGW is not difficult, however, and there are binary
> distributions too.
Thank you for your reply !
As a first turn around, I used the compiled files of Geo::Gdal of
GeoInformatica in my ActivePerl directories. It is not very clean but it
works well !
I did not found time to compile perl with MinGW yet, but I hope to be able
to try soon.
Cheers,
Guillaume.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091028/1c7f9d4a/attachment.html
