[gdal-dev] driver paths - either/or
Wed Oct 28 14:25:25 EDT 2009
William Kyngesburye wrote:
> I just noticed that when setting GDAL_DRIVER_PATH in the environment, it
> overrides the paths configured into GDAL, instead of adding to those
> paths.  Was this intentional?  Any way to tell GDAL to *add*
> GDAL_DRIVER_PATH to the configured paths?
> I want to override the installed GRASS plugin when starting up GRASS to
> point to a version compatible with the GRASS being started.
> ie:
> installed plugin: gdal_ & ogr_GRASS v6.4
> also installed as a plugin: gdal_ECW_JP2ECW
> GDAL_DRIVER_PATH=/path/to/GRASS-6.5/lib/gdalplugins (gdal_ & ogr_GRASS
> v6.5)
> So, the v6.5 plugin is loaded, but now I don't have my ECW plugin.
William,
There is no way to ask that GDAL_DRIVER_PATH be added to the default
path, but it can hold a list of directories so you can supply the new
directory and the old directories.
eg.
GDAL_DRIVER_PATH=path/to/GRASS-6.5/lib/gdalplugins:/path/to/normal/gdal/plugins
