[gdal-dev] Proper GDAL include structure
Chris 'Xenon' Hanson xenon at alphapixel.com
Fri Oct 30 18:13:26 EDT 2009
I'm building GDAL from source on Windows using the release-1400-dev.zip kit from:
http://vbkto.dyndns.org:1280/sdk/Default.aspx
This works great (though the zipfile has fairly old GDAL source and needs an SVN update to
be current). However, when it's all done building (via nmake) I don't have a single
"include" directory where all the proper .h files are located the way the FWTools release
sets things up.
Is there a step i'm missing that will collect all the necessary GDAL .h files form their
respective subdirectory and put them into one place the way FWTools provides them?
Chris 'Xenon' Hanson, omo sanza lettere                  Xenon AlphaPixel.com
PixelSense Landsat processing now available! http://www.alphapixel.com/demos/
"There is no Truth. There is only Perception. To Perceive is to Exist." - Xen
