[gdal-dev] Version of lib HDF5 Included in Gdal 1.62
Tamas Szekeres szekerest at gmail.com
Tue Sep 1 09:34:24 EDT 2009
The automated builders at http://vbkto.dyndns.org:1280/sdk  use hdf5-1.8.2
but I suspect the recent stable version (1.8.3) would also work.
You could also download ready to use SDK packages from this location to
compile gdal with hdf5 easily.
Best regards,
Tamas
2009/9/1 atubar <atubar at 126.com>
> I'm a freshman, and I want to support HDF5 format in my program by using
> gdal, which version of lib HDF5 should be added to Gdal, 1.6.X or 1.8.x?
> It seems that 1.8.x has taken great changes. And it seems that gdal
> recommands 1.6.x, for c:\warmerda\supportlibs\hdf5\5-164-win
> listed in nmake.opt.
> By the way, are all files of HDF5 format  suported by gdal integrated with
> HDF5 ? I used a sample data from HDFview package, there was an error of
> stack overflow while working with VS2008?
> ûÓйã¸æµÄÖÕÉíÃâ·ÑÓÊÏä,www.yeah.net <http://www.yeah.net/?from=footer>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090901/0c3c6271/attachment.html
