[gdal-dev] is Antarctic Polar Stereographic (EPSG:3031) properly handled by GDAL?
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Tue Sep 1 12:28:49 EDT 2009
Hi list,
I'm working on a geotiff image which is projected as EPSG:3031 (Antarctic
Polar Stereographic).
When running the last fwtools's gdalinfo, I get the following:
Coordinate System is:
PROJCS["WGS 84 / Antarctic Polar Stereographic",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.2572235630016,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4326"]],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","3031"]]
It seems that the projection part is missing (taking a look here:
http://spatialreference.org/ref/epsg/3031/prettywkt/)
Also trying to run a gdal_translate specifying -a_srs EPSG:3031 the
projection definition of the newly created tiff is still missing.
Does anyone has additional information on that topic?
Thank you very much.
Regards,
Daniele
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax:     +39 0584983027
mob:   +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090901/8924d47e/attachment.html
