[gdal-dev] Version of lib HDF5 Included in Gdal 1.62
Tamas Szekeres szekerest at gmail.com
Wed Sep 2 02:12:01 EDT 2009
To install the plugins, you should set GDAL_DRIVER_PATH to point to the
plugin directory ie:
SET GDAL_DRIVER_PATH=[package dir]\bin\gdal\plugins
or
create a \gdalplugins directory from where the executable is running any
copy the plugin dll-s into this directory.
Best regards,
Tamas
2009/9/1 atubar <atubar at 126.com>
> Hello, thanks for your help.
> I check the release-1500-gdal-1-6-mapserver-5-4 package, and find out that
> gdal_HDF5.dll and gdal_HDF5Image.dll are under the folder \bin\gdal\plugins.
> To make HDF5 work well, these two dlls are essential, is it?
> By the way, It seems that these two dlls are copied to that folder
> automatically by Makefile file under the root of release-1500-dev.
> If I compile gdal 1.6.2 with lib hdf5 by myself, I should copy
> gdal_HDF5.dll and gdal_HDF5Image.dll manually?
> Is there a way to do this automatically while compiling by myself?
> And it seems that PLUGINDIR = $(BINDIR)\gdalplugins listed in nmake.opt of
> gdal is useless.
> ÔÚ2009-09-01 21:34:24£¬"Tamas Szekeres" <szekerest at gmail.com> дµÀ£º
> Hi,
> The automated builders at http://vbkto.dyndns.org:1280/sdk  use hdf5-1.8.2
> but I suspect the recent stable version (1.8.3) would also work.
> You could also download ready to use SDK packages from this location to
> compile gdal with hdf5 easily.
> Best regards,
> Tamas
> ûÓйã¸æµÄÖÕÉíÃâ·ÑÓÊÏä,www.yeah.net <http://www.yeah.net/?from=footer>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090902/0253cfb4/attachment.html
