[gdal-dev] Shapefile to Arc/info ascii
Jonas Malmqvist jonas.malmqvist at fsdynamics.se
Thu Sep 3 10:30:56 EDT 2009
Hi all,
I've been looking around in your mailing list searching for a way to
convert a vector shapefile to a raster Arc/Info ascii format but haven't
found any applicable example. It seems like rasterize could be a
solution in the GDAL library but I don't get how.  The steps I'm aiming
to perform are the ones below, can  GDAL do that?
*Put together a mosaic of several shape files into one single shape file.
*Crop a rectangular area of the new shape file.
*Rasterize the new shapefile file (all shapes should be used) with a
specific resolution in x and y and specify which attribute column that
should be rasterized.
Thank you,
Jonas Malmqvist
Jonas Malmqvist
FS Dynamics AB
Jungmansgatan 31
SE-413 11 Göteborg
Sweden
Phone: +46 (0)31 720 71 45
Fax:   +46 (0)31 761 99 49
E-mail:	jonas.malmqvist at fsdynamics.se
