[gdal-dev] Seek error accessing TIFF directory
Thu Sep 3 13:15:43 EDT 2009
Matt Bartolome wrote:
> Hello list,
> I just compiled gdal 1.6.2 on my fedora 10 box from source. I'm in the
> process of evaluating some 2009 imagery in geotiff format. I've tried
> compiling with external libs and internal options with the same
> result.
> # ./configure --with-libtiff=internal --with-geotiff=internal
> When processing the tiff with mapnik rendering library I get:
> UserWarning: TIFFReadDirectory [myfile].tif  Seek error accessing TIFF
> directory (encountered during parsing of layer 'imagery')
> I'm not sure what function of gdal is being called by mapnik but
> things like gdalinfo, gdalwarp seem to work without any issues its
> just when rendering a tile with mapnik.
> When I compile against gdal version 1.5.3 (package install with fedora
> 10) everything seems to work as expected.
> Any suggestions or is this a bug in the newer version?
Matt,
I have no reason to believe this represents a bug in GDAL.
I would suggest you compile with the system libtiff as it is fairly
likely that mapnik depends on other libraries that also use libtiff
in which case mixing the internal GDAL libtiff and the system libtiff
could cause all sorts of problems.
Also, you need to do a "make clean" after a re-configure.  GDAL's makefiles
try to avoid unnecessary recompilation but in some cases it is at the cost
of not forcing rebuild of stuff that ought to have been recompiled (for
instance after reconfiguring).
If the problem persists you would pretty much need to track it
down in gdb, or perhaps with valgrind.  Pay particular attention to the
possibility of more than one libtiff ending up in the final process.
Best regards,
