SV: [gdal-dev] PostgreSQL, PostGIS and ogr2ogr
Even Rouault even.rouault at mines-paris.org
Tue Sep 8 13:53:36 EDT 2009
Selon Casper Børgesen <cbo at le34.dk>:
> A small follow-up. As I stated previously, the '--config PGCLIENTENCODING
> format' didn't help me. But calling 'SET PGCLIENTENCODING=LATIN1' before the
> call to ogr2ogr, did do the trick. Thus my shape file character encoding
> probably is LATIN1.
> Do you have any idea of how to get the '--config' method to work?
Indee, it can't work. I must apologize for that inacurate hint. PGCLIENTENCODING
is really an environment variable recognized by the PostgreSQL client library. I
thought that it was a OGR configuration option, which isn't. So that's explain
why --config doesn't work for that.
(GDAL/OGR has a few configuration options that can be either set by setting an
OS environmenent variable or with the --config command line parameter.)
> Regards, Casper
> -----Oprindelig meddelelse-----
> Fra: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] På vegne af Casper Børgesen
> Sendt: 7. september 2009 08:57
> Til: gdal-dev at lists.osgeo.org
> Emne: SV: [gdal-dev] PostgreSQL, PostGIS and ogr2ogr
> Okay and thank you for your answers!
> Since using the '--config PGCLIENTENCODING format' option didn't make a
> difference, my next guess is that the encoding of the shapefile might be the
> problem. I have used SQL_ASCII, LATIN1, LATIN9, WIN1250, WIN1252 as formats
> and I still get the error. The formats has been selected according to my
> location (Denmark).
> Do you have any suggestions to how I should proceed?
> Fra: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sendt: 4. september 2009 16:28
> Til: Casper Børgesen
> Cc: gdal-dev at lists.osgeo.org
> Emne: Re: [gdal-dev] PostgreSQL, PostGIS and ogr2ogr
> I'm not sure about options='-c client_encoding=latin1', but setting
> PGCLIENTENCODING=LATIN1 instead as an environmnent variable/configuration
> option should definitely work (provided that the source shape is effectively
> LATIN1
> encoded)
> ogr2ogr --config PGCLIENTENCODING LATIN1 -f PostgreSQL PG:"host=localhost
> user=username dbname=dbname password=password" sourcefile
> > Hi folks!
> > I hope you can help me. I have searched google for answers, but
> > haven't found any. So I thought going closer to the 'source' might help me.
> > In my organisation, we work with various GIS data in different file
> formats.
> > I have a project, where I need to put all these data into a PostGIS
> database.
> > So far I'm using the command line tool ogr2ogr to inject the data. But
> > I have problems with character encoding:
> > ERROR 1: INSERT command for new feature failed.
> > ERROR: invalid byte sequence for encoding "UTF8": 0xf8
> > HINT: This error can also happen if the byte sequence does not match
> > the encoding expected by the server, which is controlled by
> "client_encoding".
> > My PostGIS database uses UTF-8 and the data I'm working with (shape)
> > is probably Latin1 encoded.
> > I found a discussion where a user suggests that the solution might be
> > to do the following:
> > ogr2ogr -f PostgreSQL PG:"host=localhost user=username dbname=dbname
> > password=password options='-c client_encoding=latin1'" sourcefile;
> > It does not seem to affect the injection. So, what am I doing wrong?
> > Kind regards, Casper
> gdal-dev mailing list
