[gdal-dev] Latest ShapeLib
Jérôme - GeoRezo.net jerome at georezo.net
Wed Sep 9 10:47:45 EDT 2009
The http://download.osgeo.org/shapelib/ is up to date contrary to
http://shapelib.maptools.org/dl
Also you have a CVS link on http://shapelib.maptools.org/
Thanks
Jérôme
Selon spbhasker bachi <spbhasker at gmail.com>:
> Thank you Chaitanya.
> I had some vintage code.. wanted to use the Latest Shapelib to upgrade
> that..
> Cheers
> Bhasker
> On Wed, Sep 9, 2009 at 7:46 PM, Chaitanya kumar CH
> <chaitanya.ch at gmail.com>wrote:
> > Bhaskar,
> > Any work done on the shapelib in GDAL's shapefile driver that is not
> > entered into the main stream shapelib 'may' cause problems with other
> > applications. If you intend to have the latest code, you can look at OGR's
> > shapefile driver code.
> > You can find OGR's shapefile driver's makefiles for gcc and VC++ at
> > http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/shape
> > On Wed, Sep 9, 2009 at 7:16 PM, spbhasker bachi <spbhasker at gmail.com>wrote:
> >> Anyone having the Latest ShapeLib ???
> >> The Latest one v 1.2.10 is located @  http://dl.maptools.org/dl/shapelib/
> >> But in the GDAL trunks i have seen Frank do a Lot of Version for the
> >> ShapeFil.H & subsequents Codes.. of DBF
> >> ANyone having the Latest ShapeLib with the Latest Makefile pl send it
> >> across..
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Best regards,
> > Chaitanya kumar CH.
