[gdal-dev] Problem with gdal_translate
Even Rouault even.rouault at mines-paris.org
Fri Sep 11 12:06:48 EDT 2009
Selon Chris Emberson <chrisemberson at hotmail.com>:
The behaviour you see is expected. -expand rgb only works for bands that have
color maps. You can transform your grey scale FILEA.asc into a RGB file by doing
this :
gdal_translate -of GTiff -co "TILES=YES" -b 1 -b 1 -b 1 FILEA.asc FILEB.tif
This will use the source band 1 for the R, G, B components of the output file.
You may need to use the scaling/translate options of gdal_translate to reduce
the dynamics to 8 bits.
> I am having trouble converting a single band raster (.asc) when using the
> GDAL utility gdal_translate (version 1.6)
> This is the command...
> gdal_translate -of GTiff -co "TILES=YES" -expand rgb FILEA.asc FILEB.tif
> I get this message....
> Error : band 1 has no color table
> I want to be able to tile this raster using Mapnik - therefore it needs to be
> a 3 band tiff - Can anyone help with this problem?
> Thanks in advance
> Chris
> _________________________________________________________________
> Save time by using Hotmail to access your other email accounts.
> http://clk.atdmt.com/UKM/go/167688463/direct/01/
