[gdal-dev] Path problem with gdal2tiles on Mac
Mano Marks mmarks at google.com
Fri Sep 11 20:47:42 EDT 2009
I'm still getting the same error, unfortunately.
Mano Marks
Geo Developer Advocate
http://twitter.com/ManoMarks
On Fri, Sep 11, 2009 at 4:27 PM, Christopher Schmidt
<crschmidt at metacarta.com> wrote:
> On Fri, Sep 11, 2009 at 03:57:11PM -0700, Mano Marks wrote:
>> Using gdal2tiles on the mac, I get an ImportError for gdal:
>> Traceback (most recent call last):
>>   File "/Library/Frameworks/GDAL.framework/Programs/gdal2tiles.py",
>> line 42, in ?
>>     import gdal
>> ImportError: No module named gdal
>> Any suggestions? I tried mucking around with paths, no luck so far.
> Using KyngChaos binaries, on a new laptop I just got today, I can do this:
> PYTHONPATH="/Library/Frameworks/GDAL.framework/Versions/1.6/Python/site-packages/" python /Library/Frameworks/GDAL.framework/Programs/gdal2tiles.py
> (This is on Snow Leopard; Tiger and older will need to install Python2.5
> from python.org.)
>> I understand that maptiler is the replacement, but it's been in alpha
>> for awhile and I'd like to create samples for people who are not
>> willing to use alpha software.
> MapTiler isn't really a replacement, just a graphical interface. You will
> likely need to have GDAL libraries in the Path still.
> -- Chris
>> Mano Marks
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Christopher Schmidt
> MetaCarta
