[gdal-dev] pixel/line mapping for two images.
Christopher Barker Chris.Barker at noaa.gov
Thu Sep 17 16:52:24 EDT 2009
Belaid MOA wrote:
> I wrote a GDAL C++ code that solves the following simple problem:
> take two images, a source image with spatial resolution 25mx25m (high
> resolution) and a destination image with spatial resolution
> 10000mx10000m (low resolution) and scale the source image so that the
> values of the pixels in the source image that are mapped to the same
> pixel P in the destination image sum up to the value of P.
you really want the sum, rather than an average?
Anyway, it seems you could use gdal_warp for this, with maybe a
multiplication at the end to get a sum rather than an average.
 > As a side
> note, the two images have different projections.
That's more than a side note -- this is trivial if there were no
projection change. Could you do them in separate steps? Change the
projection of the high-res image, then do your down sampling. That might
make it pretty easy to do with the gdal utilities.
> Briefly, the arithmetic that computes the overlap is:
given your large difference in resolution, you may be able to keep it
simpler -- only use those pixels in the source wholly contained in the
destination pixel -- I doubt you'd see a difference.
>  As you can see, the ratio 1/2*(SrcXRes/DstXRes) is so small that I do
> not get smooth image
That's a big change in resolution if your source data is not that
smooth, you're not going to get a smooth result.
> Am I doing something wrong in my arithmetic?
not that I could quickly see, but give yourself some really simple test
cases to make sure.
You also might want to test without the re-projection, as that will be
easier to see if you've done it right.
> Should I apply an average filter to smoothen the image?
That is entirely dependent on your application.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
