[gdal-dev] Re:
Thu Sep 17 17:37:42 EDT 2009
Jason Roberts wrote:
> Given that the .tif itself was not touched, it seems that the statistics
> were stored in the .aux file. If this is true, do you think ArcGIS will pay
> attention to the .aux.xml file that GDAL will generate? I don't know much
> about this stuff so your guess is better than mine.
Jason,
I'm not sure - it depends on whether ArcGIS 9.3.1 is using GDAL for GeoTIFF
yet or not.  I *think* it is, but I am terrible at keeping track of what is
in what version.  I'd just suggest you try it.
BTW, it is *possible* to generate the .aux with GDAL with statistics in it,
but it is rather complicated.  I think you can do something like:
   gdal_translate -of HFA -co AUX=YES -co STATISTICS=YES xxx.tif xxx.aux
> Also, please disregard my previous claim that ArcGIS 9.3.1 was not able to
> recognize the NoData value written by the GTiff driver. I got confused about
> which machine I was using and tested that scenario with ArcGIS 9.1. I can
> confirm that ArcGIS 9.3.1 does recognize the NoData value properly in the
> scenario above.
Good - that *suggests* that 9.3.1 is using GDAL for GeoTIFF since the
nodata values are stored in the TIFF in a GDAL specific way.
Best regards,
