[gdal-dev] Recent Windows binaries?
Tamas Szekeres szekerest at gmail.com
Fri Sep 18 08:51:43 EDT 2009
I've now reconfigured to port 80 either, it that helps:
http://vbkto.dyndns.org/sdk/
Best regards,
Tamas
2009/9/18 Christopher Barker <Chris.Barker at noaa.gov>
> Tamas Szekeres wrote:
>> You may get the most recent versions compiled daily from the development
>> and stable branches from this location
>> http://vbkto.dyndns.org:1280/sdk/
> Thanks, it took a bit of manipulating, as those are not installed quite the
> same way.
> Also, port 1280 is blocked by our firewall, so I had to find a way to
> download it from outside our system.
> In short, it would be really nice if:
>     http://download.osgeo.org/gdal/win32/1.6/
> had up to date binaries...
> -Chris
> Christopher Barker, Ph.D.
> Oceanographer
> Emergency Response Division
> NOAA/NOS/OR&R            (206) 526-6959   voice
> 7600 Sand Point Way NE   (206) 526-6329   fax
> Seattle, WA  98115       (206) 526-6317   main reception
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090918/64c94371/attachment.html
