[gdal-dev] Re: Problem with gdal_translate
Hermann Peifer peifer at gmx.eu
Mon Sep 21 12:07:01 EDT 2009
gdal_translate -scale src_dataset.asc dst_dataset.tif
-scale [src_min src_max [dst_min dst_max]]:
     Rescale the input pixels values from the range src_min to src_max
to the range dst_min to dst_max. If omitted the output range is 0 to
255. If omitted the input range is automatically computed from the
source data.
see: http://gdal.org/gdal_translate.html
By the way: TILES is not a valid creation option (TILED however is).
Hermann
Chris Emberson wrote:
> Thanks for your reply.
> Would you be able to give me an example of the syntax for the
> gdal_translate option*?
> *How do I change the dynamics to 8 bits?*
> -scale* /[src_min src_max [dst_min dst_max]]/:
> Thanks
> Chris
>  > Date: Fri, 11 Sep 2009 18:06:48 +0200
>  > From: even.rouault at mines-paris.org
>  > To: chrisemberson at hotmail.com
>  > CC: gdal-dev at lists.osgeo.org
>  > Subject: Re: [gdal-dev] Problem with gdal_translate
>  > Selon Chris Emberson <chrisemberson at hotmail.com>:
>  > The behaviour you see is expected. -expand rgb only works for bands
> that have
>  > color maps. You can transform your grey scale FILEA.asc into a RGB
> file by doing
>  > this :
>  > gdal_translate -of GTiff -co "TILES=YES" -b 1 -b 1 -b 1 FILEA.asc
> FILEB.tif
>  > This will use the source band 1 for the R, G, B components of the
> output file.
>  > You may need to use the scaling/translate options of gdal_translate
> to reduce
>  > the dynamics to 8 bits.
>  > > I am having trouble converting a single band raster (.asc) when
> using the
>  > > GDAL utility gdal_translate (version 1.6)
>  > > This is the command...
>  > > gdal_translate -of GTiff -co "TILES=YES" -expand rgb FILEA.asc
> FILEB.tif
>  > > I get this message....
>  > > Error : band 1 has no color table
>  > > I want to be able to tile this raster using Mapnik - therefore it
> needs to be
>  > > a 3 band tiff - Can anyone help with this problem?
>  > > Thanks in advance
>  > > Chris
>  > > _________________________________________________________________
>  > > Save time by using Hotmail to access your other email accounts.
>  > > http://clk.atdmt.com/UKM/go/167688463/direct/01/
> View your other email accounts from your Hotmail inbox. Add them now.
> <http://clk.atdmt.com/UKM/go/167688463/direct/01/>
> gdal-dev mailing list
