[gdal-dev] gdal_rasterize with a NetCDF file?
Even Rouault even.rouault at mines-paris.org
Mon Sep 21 14:26:01 EDT 2009
Selon Scott Lewis <scott.lewis at nsidc.org>:
Scott,
Anytime you want to access to a subdataset with a gdal utility, you must use the
value of the relevant SUBDATASET_xxx_NAME metadata item, in that instance
'NETCDF:"Albedo.nc":Albedo_with_1400_Local_Time_of_Measurement'
The segmentation fault however wasn't expected, so I commited fixes per ticket
http://trac.osgeo.org/gdal/ticket/3146 to error out more nicely.
Best regards
> Hi,
> I'm still fairly new at using GDAL, but I am having trouble burning a
> vector image onto a NetCDF file.  I've had success with using
> gdal_rasterize to burn a vector onto a GeoTIFF file, but when I try to
> burn the same vector onto a NetCDF file, I get an error.
> Based on the error, I'm suspecting it's because it doesn't know how to
> find the right "band" in the NetCDF File (I want the
> "Albedo_with_1400_Local_Time_of_Measurement" subdataset), but although
> I've looked at the documentation, I'm not sure how to specify this to
> gdal_rasterize.
> Any help would be much appreciated!  Below is the info.
> Here is the command I am trying to run:
> /usr/local/FWTools-2.0.6/bin_safe/gdal_rasterize -i -burn 0 -l
> "OGRGeoJSON" dummy.json Albedo.nc
> And the error I get:
> ERROR 5: GDALDataset::GetRasterBand(1) - Illegal band #
> /usr/local/FWTools-2.0.6/bin_safe/gdal_rasterize: line 9: 26950
> Segmentation fault      $FWTOOLS_HOME/bin/`basename $TARGET` "$@"
> Here is the gdalinfo for Albedo.nc:
> Driver: netCDF/Network Common Data Format
> Files: Albedo.nc
> Size is 512, 512
> Coordinate System is `'
> Metadata:
>   NC_GLOBAL#Conventions=CF-1.4
>   NC_GLOBAL#institution=National Snow & Ice Data Center, Boulder, CO
>   NC_GLOBAL#title=AVHRR Polar Pathfinder Twice-Daily 5 km EASE-Grid
> Composites Albedo
>   NC_GLOBAL#source=See the title and references for this information
>   NC_GLOBAL#comment=Not set at this time
>   NC_GLOBAL#references=Documentation available at:
> http://nsidc.org/data/docs/daac/nsidc0066_avhrr_5km.gd.html
>   NC_GLOBAL#history=Mon, 21 Sep 2009 09:31:24: File created.
> Subdatasets:
SUBDATASET_1_NAME=NETCDF:"Albedo.nc":Albedo_with_1400_Local_Time_of_Measurement
>   SUBDATASET_1_DESC=[1x244x242]
> Albedo_with_1400_Local_Time_of_Measurement (8-bit integer)
>   SUBDATASET_2_NAME=NETCDF:"Albedo.nc":latitude
>   SUBDATASET_2_DESC=[244x242] latitude (64-bit floating-point)
>   SUBDATASET_3_NAME=NETCDF:"Albedo.nc":longitude
>   SUBDATASET_3_DESC=[244x242] longitude (64-bit floating-point)
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,  512.0)
> Upper Right (  512.0,    0.0)
> Lower Right (  512.0,  512.0)
> Center      (  256.0,  256.0)
> And for completeness, the dummy.json file (it's basically a triangle):
>     "type": "FeatureCollection",
>     "features": [{
>         "type": "Feature",
>         "properties": { "BASIN_ID": 1.000000, "AREA_SQKM": 1739.016470 },
>         "geometry": {
>             "type": "Polygon",
>             "coordinates": [ [
>                 [ -2000000, -2500000 ],
>                 [ -2500000, -1400000 ],
>                 [ -1500000, -1400000 ],
> Thanks!
> Scott Lewis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
