[gdal-dev] Re: gdal_rasterize with a NetCDF file?
Scott Lewis scott.lewis at nsidc.org
Mon Sep 21 14:49:11 EDT 2009
Ah, thanks.  I must have missed that.  Looks like I'll have to find
another way to accomplish what I'm trying to do then!
Thanks for your help!
Scott
Hermann Peifer wrote:
> The driver doesn't support updating netCDF files. gdalinfo --formats says:
>  GTiff (rw+): GeoTIFF
>  netCDF (rw): Network Common Data Format
> The "+" indicates update support, which is obviously missing for netCDF
> format.
> Hermann
> -------- Original Message  --------
> Subject: Re:gdal_rasterize with a NetCDF file?
> From: Scott Lewis <scott.lewis at nsidc.org>
> To: Date: 21/09/2009 20:37
>> Evan,
>> Thanks, that seems to be getting me in the right direction: I'm no
>> longer getting the segfault error, or "ERROR 5" at all.
>> However, now it's giving me a different error.  The first line has the:
>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>> message, like I would expect from when I do this with GeoTIFF files.
>> But following that I am getting a whole bunch of this error, repeated
>> many times:
>> ERROR 6: WriteBlock() not supported for this dataset.
>> Doing a search online, I'm getting the impression that this might mean
>> that gdal_rasterize doesn't support writing to a NetCDF file?  Is this
>> correct, or does the problem lie elsewhere with my calling of the
>> utility.
>> Here's the command line I'm using now:
>> /usr/local/FWTools-2.0.6/bin_safe/gdal_rasterize -i -burn 0 -l
>> "OGRGeoJSON" dummy.json
>> 'NETCDF:"Albedo.nc":Albedo_with_1400_Local_Time_of_Measurement'
>> Thanks again for the help!
>> Scott
>> Even Rouault wrote:
>>> Selon Scott Lewis <scott.lewis at nsidc.org>:
>>> Scott,
>>> Anytime you want to access to a subdataset with a gdal utility, you
>>> must use the
>>> value of the relevant SUBDATASET_xxx_NAME metadata item, in that
>>> instance
>>> The segmentation fault however wasn't expected, so I commited fixes
>>> per ticket
>>> http://trac.osgeo.org/gdal/ticket/3146 to error out more nicely.
>>> Best regards
>>>> Hi,
>>>> I'm still fairly new at using GDAL, but I am having trouble burning a
>>>> vector image onto a NetCDF file.  I've had success with using
>>>> gdal_rasterize to burn a vector onto a GeoTIFF file, but when I try to
>>>> burn the same vector onto a NetCDF file, I get an error.
>>>> Based on the error, I'm suspecting it's because it doesn't know how to
>>>> find the right "band" in the NetCDF File (I want the
>>>> "Albedo_with_1400_Local_Time_of_Measurement" subdataset), but although
>>>> I've looked at the documentation, I'm not sure how to specify this to
>>>> gdal_rasterize.
>>>> Any help would be much appreciated!  Below is the info.
>>>> Here is the command I am trying to run:
>>>> "OGRGeoJSON" dummy.json Albedo.nc
>>>> And the error I get:
>>>> ERROR 5: GDALDataset::GetRasterBand(1) - Illegal band #
>>>> /usr/local/FWTools-2.0.6/bin_safe/gdal_rasterize: line 9: 26950
>>>> Segmentation fault      $FWTOOLS_HOME/bin/`basename $TARGET` "$@"
>>>> Here is the gdalinfo for Albedo.nc:
>>>> Driver: netCDF/Network Common Data Format
>>>> Files: Albedo.nc
>>>> Size is 512, 512
>>>> Coordinate System is `'
>>>> Metadata:
>>>>   NC_GLOBAL#Conventions=CF-1.4
>>>>   NC_GLOBAL#institution=National Snow & Ice Data Center, Boulder, CO
>>>>   NC_GLOBAL#title=AVHRR Polar Pathfinder Twice-Daily 5 km EASE-Grid
>>>> Composites Albedo
>>>>   NC_GLOBAL#source=See the title and references for this information
>>>>   NC_GLOBAL#comment=Not set at this time
>>>>   NC_GLOBAL#references=Documentation available at:
>>>> http://nsidc.org/data/docs/daac/nsidc0066_avhrr_5km.gd.html
>>>>   NC_GLOBAL#history=Mon, 21 Sep 2009 09:31:24: File created.
>>>> Subdatasets:
>>> SUBDATASET_1_NAME=NETCDF:"Albedo.nc":Albedo_with_1400_Local_Time_of_Measurement
>>>>   SUBDATASET_1_DESC=[1x244x242]
>>>> Albedo_with_1400_Local_Time_of_Measurement (8-bit integer)
>>>>   SUBDATASET_2_NAME=NETCDF:"Albedo.nc":latitude
>>>>   SUBDATASET_2_DESC=[244x242] latitude (64-bit floating-point)
>>>>   SUBDATASET_3_NAME=NETCDF:"Albedo.nc":longitude
>>>>   SUBDATASET_3_DESC=[244x242] longitude (64-bit floating-point)
>>>> Corner Coordinates:
>>>> Upper Left  (    0.0,    0.0)
>>>> Lower Left  (    0.0,  512.0)
>>>> Upper Right (  512.0,    0.0)
>>>> Lower Right (  512.0,  512.0)
>>>> Center      (  256.0,  256.0)
>>>> And for completeness, the dummy.json file (it's basically a triangle):
>>>>     "type": "FeatureCollection",
>>>>     "features": [{
>>>>         "type": "Feature",
>>>>         "properties": { "BASIN_ID": 1.000000, "AREA_SQKM":
>>>> 1739.016470 },
>>>>         "geometry": {
>>>>             "type": "Polygon",
>>>>             "coordinates": [ [
>>>>                 [ -2000000, -2500000 ],
>>>>                 [ -2500000, -1400000 ],
>>>>                 [ -1500000, -1400000 ],
>>>> Thanks!
>>>> Scott Lewis
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
