[gdal-dev] ERROR 6: SetNoDataValue() not supported for this dataset.
Even Rouault even.rouault at mines-paris.org
Mon Sep 21 17:27:26 EDT 2009
Selon Joaquim Luis <jluis at ualg.pt>:
I can't reproduce your issue with trunk, nor can I understand how it can happen.
This error message is thrown when a driver doesn't implement the
SetNoDataValue() method. But the GTiff driver has supported it for ages.
> Hi,
> In this example I get the (apparently innocuous) error message below.
> The file is correctly converted, but why is it complaining?
> gdal_translate w020n40.Bathymetry.srtm lixo.tiff
> Input file size is 4800, 6000
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> w020n40.Bathymetry.hdr
> BYTEORDER     M
> LAYOUT        BIL
> NROWS       6000
> NCOLS       4800
> NBANDS        1
> NBITS         16
> PIXELTYPE  SIGNEDINT
> BANDROWBYTES  9600
> TOTALROWBYTES 9600
> BANDGAPBYTES  0
> NODATA        -32768
> ULXMAP        -19.9958333333333
> ULYMAP        39.9958333333333
> XDIM         0.008333333333333
> YDIM         0.008333333333333
> Joaquim Luis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
