[gdal-dev] ERROR 6: SetNoDataValue() not supported for this dataset.
Joaquim Luis jluis at ualg.pt
Mon Sep 21 17:53:43 EDT 2009
Yes, strange it is. I'm using trunk as well (from yesterday) but I don't get it
when I use FWTools.
Even weirder, I used GTiff just as an easy example but the original place where
I saw it is with my gdalread MEX, which only reads a dataset and does not attempt
to write it anywhere.
Even Rouault wrote:
> Selon Joaquim Luis <jluis at ualg.pt>:
> I can't reproduce your issue with trunk, nor can I understand how it can happen.
> This error message is thrown when a driver doesn't implement the
> SetNoDataValue() method. But the GTiff driver has supported it for ages.
>> Hi,
>> In this example I get the (apparently innocuous) error message below.
>> The file is correctly converted, but why is it complaining?
>> gdal_translate w020n40.Bathymetry.srtm lixo.tiff
>> Input file size is 4800, 6000
>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>> w020n40.Bathymetry.hdr
>> BYTEORDER     M
>> LAYOUT        BIL
>> NROWS       6000
>> NCOLS       4800
>> NBANDS        1
>> NBITS         16
>> PIXELTYPE  SIGNEDINT
>> BANDROWBYTES  9600
>> TOTALROWBYTES 9600
>> BANDGAPBYTES  0
>> NODATA        -32768
>> ULXMAP        -19.9958333333333
>> ULYMAP        39.9958333333333
>> XDIM         0.008333333333333
>> YDIM         0.008333333333333
>> Joaquim Luis
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
